I have a 97 rs camaro, when you put the parking brake down only the drivers side driving light will come on, the passenger one will not, and after it sits or I drive it for awhile it will come on, and if I'm driveing at night the pass., side is dimmer than the driver side, anyone have any clues on what it could be?
half of the lights on my car are dimm
maybe need a new bulb?97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
Check the bulb socket contacts and see if they're corroded. Might need to clean them off with some sandpaper. Test the socket with a multimeter to see if it's getting the same voltage as the other side.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Tell-tale sign of a poor ground. Check the socket first, but if that's not the issue, try to find a wiring diagram and hunt down the grounds for both lights.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
