So im installing my DIS-4 today and i got everything done...i started it up gave it a few revs and all and everythin was fine...i didnt have any codes comin up or anythin...so i go to take my car out of the driveway and all of a sudden it just dies...no power after that!! No headlights, interior lights the cluster doesnt show signs of life...then i start messin with the battery try to c if i didnt tighten it enought and all of a sudden i hear the fuel pump come on and then i started it back put...sat in the car and it died again!! what the heck is goin on with my car now!!
HELP!! No power to anythin!!
Re: HELP!! No power to anythin!!
That sounds like a bad ground. You should check the battery negative wire to make sure its grounding on the frame properly. I had a similar problem in my triumph with it getting intermittent power. I had to remove the negative on the battery where it connects to the frame clean it with a wire brush and reconnect it.
That’s all i can think of, Goodluck!MSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
yea sounds like a ground is not quite tight enough somewhere. When you were messing with your battery you probably moved it enough to touch metal again and it started until it was shaken loose again. Check the wiring
well i just finished takin the DIS-4 out...i must of had somethin loose...but once i regained power i tried to start it and nothing...i looked at the box and i noticed that it was blinking now...when i had it running b4 the light was just on and no blinking...so i just took it out...so the whole day was a waste basically except for the fact that i moved my coils forward now lol...took me 5 hrs to do that lol
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
Originally posted by SilverRS96so the whole day was a waste basically except for the fact that i moved my coils forward now lol...took me 5 hrs to do that lol2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
www.turbov6camaro.com in his mod guide shows u how to do it...mine looks just like his
87 Firebird RIP
96 Camaro RS RIP
02 WS6 TA - Sold
ya, i've seen that guide for that mod before. I still dont see where he drilled2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
if u look at it u c that there is only 1 nut now on the plate instead of 2...when u look at it ull c where the 2 studs come threw the plate. i drilled a new hole 2 slots back from the front hole...sounds kinda confusing but when u look at it u should pick up on what im talkin about
87 Firebird RIP
96 Camaro RS RIP
02 WS6 TA - Sold
