the car runs fine i just installed a carsound cat 3" in 3" out wit magnaflow catback and a cutout ...i do not have an intake so i do not kno if this is causing the problem ....my rpms from a dead start move up like a clocks second hand like in like ticks idk wat it is and the car accelerates horribly and i feel as if i need to floor it on the highway just to get 5mph quicker i need help and quick!
power loss need help from someone!
Re: power loss need help from someone!
i was thinking about doing a 3 in and 3" out, and a cat back. think im gong to hold off untill you figure out your problem..lol Im just GUESSING, i have no idea, but could it have taken so much back pressure off the engine, that it would be causing this probem, i high doubt it, but maybe.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
what year is this car<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Originally posted by BobbyZ72i was thinking about doing a 3 in and 3" out, and a cat back. think im gong to hold off untill you figure out your problem..lol Im just GUESSING, i have no idea, but could it have taken so much back pressure off the engine, that it would be causing this probem, i high doubt it, but maybe.
I've run with open y-pipe before
I've seen friends with open headers2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
check the fuel filter<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
I have seen 4 cylinder Hondas run with open headers and no power loss. I dont see how expelling exaust gas faster will make an engine weaker. Its a wives tale and most ASE tecs will agree (chime in tecs). The only exaust system required on an engine is pipes long enough to guide the hot exaust away from the head.
This is no joke I have an 86 firebird with a 350 in it. When I ran open headers it was hard for me to smoke the tires. Then when I put on 2.5" duals it moved the torque range down into the power range and I have no trouble smoking my tires now. Do I understand it? No, but with my cam I could definitely tell a difference.
Originally posted by camaroz87the car runs fine i just installed a carsound cat 3" in 3" out wit magnaflow catback and a cutout ...i do not have an intake so i do not kno if this is causing the problem ....my rpms from a dead start move up like a clocks second hand like in like ticks idk wat it is and the car accelerates horribly and i feel as if i need to floor it on the highway just to get 5mph quicker i need help and quick!
You will lose some low-end with less back-pressure. When my cat went out, I was runnin open y-pipe, and noticed loss of low-end, but gains in high-end. It wouldn't cause what he is describing which is the loss on the highway.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Originally posted by AceSo was your car quick and then u put these parts on and all of a sudden "power loss"? When u say u dont have an intake do u mean intake manifold or cold air intake? Or do u mean open throtle body? Is your computer throwing any codes?
before, you never said you were misfiring. Are you?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
