is there a way to change all the transmission fluid myself without having to take it to a dealer for a $200 flush?
transmission fluid
Re: transmission fluid
yes, drop the pan 1, 2 or 3 times. or stick a small hose down the dip stick tube, pump out all you can, refill, drive around, repeat a few time.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
yes you can. all you do is remove the pan, change the filter, put new gasket and pan on, fill. flushes are fine but whats the point of doing all that and spending so much when you still have the old filter in the tranny...you know? the only thing it has on a filter change is old fluid does stick around in some places and you still have the gunk stuck in some places. I love the flush then filter change combo. can get expensive if your not doing it yourself though.
i forgot about that fluid in the lines and radiator
Could a air compressor be used?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
All you have to do is FRESHEN IT UP, you guys worry too much.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Laugh out Loud.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
