LS1 injectors - FirebirdV6.com/CamaroV6.com Message Board
LS1 injectors
  • LS1 injectors
    Hey guys after my tune as I htink Ive said before my stock 20lbs injectors are almost at max. I bought a set of LS1 stock 26.4lb injectors off a guy who has a Camaro SS. He sold them to me for 60 bucks and they have 75k miles on them. Was that a good deal for those injectors or not.
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    AR stage 3 heads/intakes to be installed
    www.cardomain.com/id/firehawknwv
    www.vaperz.com
    PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
    Re: LS1 injectors
    First, stock are 22#
    second, I got my GTP 36# injectors for $50 shipped.
    60 bucks isn't bad, but you could have got the 36# for cheaper. They are always for sale for $50.
    http://www.bowtiev6.com/
      Re: LS1 injectors
      Duno bout them being 22lbs because HPtuners has mine as 20lbs.
      www.vaperz.com
        Re: LS1 injectors
        I dont believe ya for lots of reasons.
        Nobodys stock injector table is just "20" straight across the board.
        I already know ours are 22 lbs
        My table reads: "20.40,20.40,20.33,20.27,20.20,20.20,20.35,20.70,2 1.25,21.95,22.77"
        You must be reading the wrong table.
        Its the table named "Injector Flow Rate vs. KPA"
        It adds more fuel as Manifold vacuum changes/increases.
        edit: my bad, thought he bought the entire fuel rail for some reason
          Re: LS1 injectors
          Originally posted by slow6
          I dont even know if we can use v8 injectors? What would you do? JB Weld the extra 2 injectors closed or something??
          Keep them as backups since only 6 are going in the car?
          It's not like he bought the entire fuel rail.
            Re: LS1 injectors
            Its not about believing man its jsut what it said under the Spec section on the tuner where it tells u what components are in the car.
            www.vaperz.com
              Re: LS1 injectors
              what version do you have? I dont have a specifications section..
              i'll have to look
              but believe me and everyone else... yours cam with 22lbs/hr
              http://engine.firebirdv6.com/
                Re: LS1 injectors
                all years except for 93-95 came with 22. 93-95 was 17
                If you have HP T. then you have 22, no doubt
                  Re: LS1 injectors
                  spec section? where is this spec section you speak of? I just go to my flow table on my stock bin and I see like 22.27 in my table
                    Re: LS1 injectors
                    Guys, guys Im not trying to start an arguement so calm down. Im just telling you what I saw. It maybe a glitch or something, but this doenst change the fact of my original post. Will thise LS1 injectors work on my car?
                    www.vaperz.com
                      Re: LS1 injectors
                      Not trying to argue, just letting you know they are 22# and whoever else reads this thread so we don't mislead and confuse people any more than they already are with injectors. As for your original post about them working on your car, you never asked that, you simply asked if it was a good deal. You would have to compare the pin style setup on the injectors to see if they work. The 95-99 ( I think it was 99 when they ended) 3.8l injectors are one style whereas the 00+ are a different style pin on the injector wiring.
                        Re: LS1 injectors
                        Yea ive heard that but I just wasnt sure if theyd work. If not then Ill sell them on LS1 tech.com
                        www.vaperz.com
                          Re: LS1 injectors
                          you've already been told by ben on that other message board that they are shorter length injectors.
                          I test it and see if the wires plug up and if it'll fit in the whole snuggly
                            Re: LS1 injectors
                            Dont get hasty. I always post on multiple forums about certain subjects. Because I get more info that way cuz not all members are members of the othre forums.
                            www.vaperz.com
                            • Andy H
                              Transmission removal help!!
                              by Andy H
                            • 2.8 Bird
                              Abs inop
                              by 2.8 Bird
                            • fishin
                              by fishin
