Hey guys after my tune as I htink Ive said before my stock 20lbs injectors are almost at max. I bought a set of LS1 stock 26.4lb injectors off a guy who has a Camaro SS. He sold them to me for 60 bucks and they have 75k miles on them. Was that a good deal for those injectors or not.
LS1 injectors
LS1 injectors
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
AR stage 3 heads/intakes to be installed
www.cardomain.com/id/firehawknwv
www.vaperz.com
PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
Tags: None
Re: LS1 injectors
First, stock are 22#
second, I got my GTP 36# injectors for $50 shipped.
60 bucks isn't bad, but you could have got the 36# for cheaper. They are always for sale for $50.
Re: LS1 injectors
Duno bout them being 22lbs because HPtuners has mine as 20lbs.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Re: LS1 injectors
Originally posted by Firehawk N WvDuno bout them being 22lbs because HPtuners has mine as 20lbs.
Nobodys stock injector table is just "20" straight across the board.
I already know ours are 22 lbs
My table reads: "20.40,20.40,20.33,20.27,20.20,20.20,20.35,20.70,2 1.25,21.95,22.77"
You must be reading the wrong table.
Its the table named "Injector Flow Rate vs. KPA"
It adds more fuel as Manifold vacuum changes/increases.
edit: my bad, thought he bought the entire fuel rail for some reasonLast edited by slow6; 07-28-2006, 01:25 AM.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: LS1 injectors
Originally posted by slow6I dont even know if we can use v8 injectors? What would you do? JB Weld the extra 2 injectors closed or something??
It's not like he bought the entire fuel rail.
Re: LS1 injectors
Its not about believing man its jsut what it said under the Spec section on the tuner where it tells u what components are in the car.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Re: LS1 injectors
what version do you have? I dont have a specifications section..
i'll have to look
but believe me and everyone else... yours cam with 22lbs/hr
http://engine.firebirdv6.com/2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: LS1 injectors
all years except for 93-95 came with 22. 93-95 was 17
If you have HP T. then you have 22, no doubt2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: LS1 injectors
spec section? where is this spec section you speak of? I just go to my flow table on my stock bin and I see like 22.27 in my table
Re: LS1 injectors
Guys, guys Im not trying to start an arguement so calm down. Im just telling you what I saw. It maybe a glitch or something, but this doenst change the fact of my original post. Will thise LS1 injectors work on my car?01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Re: LS1 injectors
Originally posted by Firehawk N WvGuys, guys Im not trying to start an arguement so calm down. Im just telling you what I saw. It maybe a glitch or something, but this doenst change the fact of my original post. Will thise LS1 injectors work on my car?
Re: LS1 injectors
Yea ive heard that but I just wasnt sure if theyd work. If not then Ill sell them on LS1 tech.com01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Re: LS1 injectors
you've already been told by ben on that other message board that they are shorter length injectors.
I test it and see if the wires plug up and if it'll fit in the whole snuggly2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: LS1 injectors
Dont get hasty. I always post on multiple forums about certain subjects. Because I get more info that way cuz not all members are members of the othre forums.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
