p0341 code - FirebirdV6.com/CamaroV6.com Message Board
p0341 code
  • p0341 code
    I am getting the p0341 code for a camshaft position sensor range or performance problem. I have changed the sensor twice and erased the code with an obdII code scanner but the code keeps coming back. Is there any other problem that would cause this code to throw or am I just getting defective sensors. I have bought sensors from 2 different auto stores. Also My car has recently began to lose power while driving and stall. is this issue related to the sensor or is it a different problem? If it is a new problem any ideas on what the cause may be? I am stumped.
    David
    Could be bad wiring, bad Cam Position Sensor (CMP), bad ICM or coil, or bad/missing magnet on the cam sprocket.
    http://www.leadingedgesim.com/mkapro...maro/P0341.htm
    Matt
    1998 Mystic Teal Camaro M5
      6 days ago
