Fuel Pump - FirebirdV6.com/CamaroV6.com Message Board
Fuel Pump
  • Fuel Pump
    My fuel pump is giving me problems. I went to Autozone and the replacement was around $350. So my question is: if I buy a walbro or any other after market fuel pump do I have to upgrade my fuel system? Do I need to get a fuel regulator? or Higher flowing injectors? Which fuel pump do you all recomend? Any help will be greatly appreciated.
    Thanks
    Black 2000 A4 v6 camaro (Y87)<br />maf screen removal, cat removal, MSD wires, K&N filter, custom ram air, Transgo shift kit, 3000 stall converter and Nitto drag radials<br />southwestdrags.com
    you wont need to upgrade anything because your stock regulator should be able to control the extra flow. from what i was reading,(searched ;) ) LS1 pumps work just as well also but make sure its "high flow" and from what i was reading, thats just the difference between LT1s and LS1s. LT1s have a lower fuel pressure and so the pump is different.
    [ November 11, 2005, 02:50 AM: Message edited by: BLLDOGG ]
    2000 3.8 A4 Pewter Camaro
