Firebird Mechanical Headlight malfunction - FirebirdV6.com/CamaroV6.com Message Board
  • Firebird Mechanical Headlight malfunction
    I have a 2001 Firebird - the headlights are malfunctioning - at first the passenger headlight just wouldn't flip up. So I would push on it, or start to wind it up manually - then for some reason it would work usually until the next morning. last night - I started to wind it up manually and turn it on - which made it come up - but when it when back down the motor that pushes it up and down kept going for a few more seconds making a loud noise. As well, now when I press lock or unlock the headlights come up halfway, then go back down and make the noise (as you know, only the fog and blinker lights are supposed to flash twice when lock/ unlock, nothing with the headlights) So, if anyone as any clue as to what this might be, I would be most appreciative.
    Re: Firebird Mechanical Headlight malfunction
    thats because your gear is stripped, you can do the free mod , just search for it, or you can buy the brass gears, but this topic has been beaten to death like many others, and a simple search will yeild your results
      thanks
      • 187shark
        by 187shark
