I've been having starting problems in my 3.4. If the engine is cold about 75% of the time it wont start when I crank it the first time. I have to let off, and crank it again, then it starts, sometimes with a POP from the exhaust. If the engine is warm, it usually fires right off. Car has a new fuel pump and filter.
Any help would be greatly appreciated. Thanks
\'95 Med. Quasar Blue Camaro 3.4 A4<br />Bunch o\' mods<br /><b>10.18 @ 67.60 mph 2.22 60 ft (1/8 mile)</b> <br /><br />-1986 Camaro with a carbed 350<br /><b>8.53 @ 81.45mph 1.8 60\'</b><br />AIM CamaroL32
My car was doing basicly the same thing, but mines a 3.8. After my car would sit for about an hour it would have this problem. From reading other posts here, i had a good idea that it was the fuel pressure regulator, it was a ***** to replace, but so far it seems to have corrected the problem.
cool. good thing your kept it! Id put it on and see if it makes a diffrence, i mean you have nonthing to loose
