i bought a new gasket, its rubber. which seemed weird cuz im used to seeing paper/metal mesh. anyone accomplished this job with no problems. seems fairly easy, i have a lot of mechanical exp. whats up with the rubber gasket? i probably need gasket sealer right?
right valve cover gasket leaking. easy?
Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.Tags: None
Re: right valve cover gasket leaking. easy?
no gasket seal, the stock ones are rubber as well, very simply install, pull the cover, remove gasket, replace gasket, re-assemble. You may have to also get the engine removal bracket out of the way.
