ok.... ive been a member here 4 awhile.... had a ? some time back about electrical prob i was having... that got worked out thank god.....now however....different issue... i broke my arm about 3 weeks ago..compound fracture both bones in my right forearm....the camaros been sittin in the garage 4 about 3 weeks i finally feel ok 2 drive it, take it out go 2 work 2 get paycheck and on way home (20 min drive 2 work) temp hits 240 then jumps 2 redline.... get home let it sit, go the next mourn 2 lubecenter get radiator flushed.....(had one about 15K miles ago though) everything seems 2 be fine now.... drive around starts 2 climb high again... go 2 autozone buy thermostat (180 degree) and gasket... later that day install it... took it 4 a drive tonight and bout 30 min into drive it starts climbing again... park it in driveway turned on... FANS do not kick on until i put it on max ac....climbed to 250ish be4 i said thats enough and parked it and kicked it (y ..bc its being stupid:rant: )
never had this problem until it sat 4 about 3 weeks... ne ideas?? radiator or water pump? car has 113K on it everything else has been serviced within 3K miles (full tune up)
i need advice asap... im suppose 2 be driving 2 myrtle beach 2mrw nite... if my car dosent run.. then im stuck takin the moms GT
aim is same as name here
