is a bcm from a 96 interchangeable with one from a 98, and does the fb/camaro make a difference?
BCM interchangeability, this ones for you blldogg
Re: BCM interchangeability, this ones for you blldogg
dont think so. the biggest difference i bet would be the communication style. call a local dealer part department, ask them to look up the modules and compair part numbers and such. are you trying to get a used one? you know that even if it is the same, that you will have to have it programmed at a dealership and you car will probably not run until then.
O' ther is soooo much more.
