fuel filter problems - FirebirdV6.com/CamaroV6.com Message Board
  • fuel filter problems
    so I am replacing my fuel filter, I relieved the schreder valve, I have the cap off, and My fuel lines will not stop spilling fuel, not even slowing down, I cant get my hand in there long enough to try and unthread the filter without gas pouring everywhere on me. HELP!
    Re: fuel filter problems
    I had to put a bucket under my filter when I did it. quite a bit came out.
    http://www.bowtiev6.com/
      Yah, normal to lose about a cup of gas, even without pressure there's plenty in the line to drain out. Long gloves and eye protection to keep from getting splashed is nice.
      2001 Pewter Firebird Y87, M5
      Go Sabres!
        I found that if you're under the filter when it begins to leak gasoline, that the gas tastes like sh*t and it gives you an upset stomach later on. I had to learn the hard way...
          lol, great advice about the affects of gas in mouth. ;)
            you should do it when you are very low on gas, so less spills out
            keep the gas tank cap off while doing it (i guess)
            gas smells good but tastes bad, its carcinogenic
              i let it fill up half a coffee can before i said **** it, so pissed today my new drive shaft is too thick and wont fit with the exhaust, and now the filter, so yea **** it, i would be much happier paying someone to do this ****.
                Just change it anyways, it does not make a diffrece that gas is running out.
                  actually, leave the cap on when you change it, so it cant breathe and will form a lock
                    wouldnt that put a bad air bubble in the fuel line? or am i crazy?
                      (totally off topic)
                      CamaroingFool- I just noticed your centercaps... I like...
                      Custom interior...
                      TEAM NoVa
                        i think you are crazy
                          lol... The heat must be gettin to me...
                          Custom interior...
                          TEAM NoVa
                            bottom line, i tried everything including replacing the cap, gas jusst kept flowing, I had a half tank in at the time, I also tried to pry the fuel filter off while gas was coming out, and the damn thing wouldnt loosen up. So tomorrow it will go in for tires, shocks, struts,...and now a fuel filter.
                              Fuel filter are so easy to change, just have a friend do it.
                              <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
