what does the hypertech 180 degree powerstat do and is it an essintal part of your modifications
powerstat
Thermostats control the flow of coolant through the engine, and therefore the temperature. Not exactly a high power mod.
http://www.camarov6.com/ubb/ultimate...c;f=1;t=015805
http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=015195Matt
1998 Mystic Teal Camaro M5
Not knowing what your vehicle is ...
I think 98 and newer already have a 180. If you go lower to a 160, some 2001s (mine), will throw a code, enriching the intake with fuel to increase the temp which will never increase due to the thermostat being open.Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
