ungraded injectors? - FirebirdV6.com/CamaroV6.com Message Board
ungraded injectors?
  • ungraded injectors?
    ok i have a 3.8L with an slp intake, no cat and a "catback" exhaust lol. i was wondering if i put headers on my car, would i run lean and need to upgrade to bigger injectors or am i fine with just leaving the ones i have
    also how many lbs are stock 3.8l injectors(something i should know, im sorry)
    Re: ungraded injectors?
    they are 22 i believe but i doubt you would need to upgrade, if dirty then just clean them.
      headers wont make you go lean, although it would be a very good idea to tune it
      just putting bigger injectors on wont make you run richer, it would probably cause problems
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
