i just got mine in and am ready to install it. the spacer come with three threaded studs. on the car their are two threaded studs and one bolt that goes in at the top. do i just need to but a nut to go on the third stud or am i missing something. its seems like that bolt would be a lot bigger in diameter then the stud. so has anyone got one of these from zzp? if so what gives? oh by the way this is on a 01 3.8.....one more quick thing, does a whipser lid need to be modified in order to run this spacer? thanks in advance, forrest.
throttlebody spacer
Re: throttlebody spacer
I got my TB spacer from zzp. for the bolt in the top i just used one of the studs and put a nut on the end of it.
As for the wisper lid, on mine it made it fit a little tighter but it still works with it.
I went for a drive and felt the TB after install and its WAY cooler to the touch than without the spacer.Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
