For some reason, every once in a while my Camaro will randomly stall. At first it was only happening at idle but the other day it actually happened while driving. When I checked the fuel pressure the pressure went to 50 psi when i put the key in the "on" position and when the pump cut off after 2 seconds the pressure dropped to 40 psi. After i actually started the car the pressure climbed back up to 43 psi. Is this normal or do i have a fuel pressure regulator problem?
Thanks for any help.
2002 Red Camaro 3.8L<br />Monsoon stereo with T-Tops
