sometimes it takes two cranks - FirebirdV6.com/CamaroV6.com Message Board
  • sometimes it takes two cranks
    sometimes it takes 2 cranks to start my car.. never really a certain time.. i crank it then stop the turn it over again and fires right up.. does this sound like a sensor
    3.4....cold air intake, flowmaster, underdrive pullys, 3.42 gears, ngk spark plugs
    Do you let it crank for a few seconds the first time then stop and it fires the second time? Or is it more like you just bumped it the first time and it didn't catch. 'Cause I've done that before, just misjudged the amount of time it took to fire.
      ya i could do it either ways.. let it crank 4 bout 3 sec. stop and it fires right up..
      sometimes i could do it the way and it wrks.
        Hmm, the only time mine is hard to start like that is the first start after cleaning the top end. Have you cleaned out the throttle body and Seafoamed the intake yet?
          i put seamfome through the gas.. ill try the other.
          and no ive never cleaned the throttle body.. whats ur opion on a bigger one.
            Pull your intake off, stuff a rag under the TB and manually open the throttle and spray TB cleaner all around and inside, you will get a river of brown run out.
            You also want to seafoam the motor through the brake booster line. There's a good writeup here about it. http://members.nuvox.net/~on.roz/cars/z28/seafoam.html
            As for a bigger TB, I'm not sure, never heard of anyone doing it on a 3.4 other than the LT1 TB intake modification.
              Do NOt Use Carb Cleaner for the TB. I read that it causes harm to something ill get back to yall on it when i find it... Hold on
                The only thing you can really dmg in a TB is a maf sensor if you spray it. I dindt think 3.4 had mafs in there TB? And if you do you can just take it out while you clean. Soak it good then wipe it clean.
                Run some seafoam or automatic trans fluid( I use ATF) in the brake booster or a good vacuum line with manifold pressure. Let it sit for like 10 mins then put about a pint of water through it put it back together then go drive it [img]smile.gif[/img]
                1999 Pontiac Trans Am M6 Far from stock.....
                  Use throttle body cleaner. Available at any auto parts place. How old is your battery...
                  97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
                    ever changed your fuel filter?
                      battery new... guess still old fuel filter.
                      i gonna try the seafoam.. but gonna have to put it on hold. i hit a deer today. gotta wait for insurance company and c what they say
                        a deer will screw up your gas mileage and insurance.
                        that sux
                          a deer screws up your gas mileage?
                          Dave:
                          00 Supercharged Camaro - RIP
                          97 Turbo Camaro - Sold
