no idea - FirebirdV6.com/CamaroV6.com Message Board
no idea
  • no idea
    well this has been a problem i have had for a while. there is a crazy knocking sound comming from the drivers side of the engine but............ its not the lifters any ideas?????
    Re: no idea
    is it a knocking or a ticking sound? Also what year and engine?
    http://www.bowtiev6.com/
      Re: no idea
      knocking 95 3.4
        Re: no idea
        its wierd my car idles around 1100 and its knocking loud but when i rev up to 2100 it stops
          Re: no idea
          How is your oil pressure?
          1997 Dodge Viper GTS
            Re: no idea
            umm its on the first tick
              Re: no idea
              Which is about what?
                Re: no idea
                well it goes to 80 and there are five marks so about 16lbs
                  Re: no idea
                  Alright, so now what happens to the oil pressure when you rev the car up?
                    Re: no idea
                    stays the same
                      Re: no idea
                      sounds like a spun bearing.
                      Follow me!
                      Or this
                        Re: no idea
                        yea sounds like you got some engine troubles, your oil psi shouldn't be that low
                          Re: no idea
                          typically when you have a spun bearing oil pressure is REAALLY low reguardless of the rpm. so im basing this on what ive personally seen. i wouldnt drive the car until its fixed. if you do you'll be spending alot of cash fixing other things.
                          Follow me!
                          Or this
                            Re: no idea
                            You should be getting something like 50+ psi of oil pressure with the throttle open.
                            That could be a large part of your problem.
                            The low oil pressure can make the lifters tick, but appear fine, and can also ruin your bearings and make the rods knock.
                              Re: no idea
                              well why does it drive fine no vibration doesnt hesitate or anything
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
