well this has been a problem i have had for a while. there is a crazy knocking sound comming from the drivers side of the engine but............ its not the lifters any ideas?????
no idea
Re: no idea
is it a knocking or a ticking sound? Also what year and engine?
Re: no idea
yea sounds like you got some engine troubles, your oil psi shouldn't be that low
Re: no idea
typically when you have a spun bearing oil pressure is REAALLY low reguardless of the rpm. so im basing this on what ive personally seen. i wouldnt drive the car until its fixed. if you do you'll be spending alot of cash fixing other things.
Follow me!
Or this
Re: no idea
You should be getting something like 50+ psi of oil pressure with the throttle open.
That could be a large part of your problem.
The low oil pressure can make the lifters tick, but appear fine, and can also ruin your bearings and make the rods knock.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...17 minutes ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 days ago
