can somebody (when you have time) list most of the v8 take offs that will fit in my 2001 firebird. again this is when you have the time to do it. appreciate the help.
v8 takeoffs
Most anything not directly related to the engine or transmission.
Suspension, driveshaft and differential are probably the most commonly swapped parts, as these are upgraded in some way for the V8. Many other parts are compatible, just not upgrades for a V6.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
like he said, everything not related to engine or trans with these exceptions:
engine cradle
radiator
fuel pump
gauge cluster
wiring harnesses
hoses (a/c and coolant)
throttle
suspension springs
ECM
since u have an '01, u have v-8 brakes so can swap those. might as well swap out the steering rack too cuz they're different but will fit both cars (the v-8 is a bit tighter ratio).2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
