HOW DO I PULL CODES ON 94 3.4. CANT USE PAPER CLIP MOUSE ATE THRU WIRES - FirebirdV6.com/CamaroV6.com Message Board
  • HOW DO I PULL CODES ON 94 3.4. CANT USE PAPER CLIP MOUSE ATE THRU WIRES
    WELL A FEW YEARS BACK I TRYED TO PULL CODES VIA SHORTING TERMINALS ON OBD-1 CONNECTOR. FOUND OUT IT DIDNT WORK. I ALSO HAD THIS HAPPEN ON A 95 CORSICA AND ALSO THE REGULAR CODE READERS DONT WORK.
    I READ SOMETHING I THINK ONCE THAT 94-95 3.4'S USE THE OBD-1 CONNECTOR BUT THE OBD-II BAUD RATE.
    DOES ANYONE KNOW 4 SURE WHATS DIFFERENT AND HOW I CAN PULL CODES....
    A MOUSE BUILT A NEST IN THE PLENUM AREA AND ATE TO WIRES, I FIXED THAT BUT SOMETHING ELSE IT MUST HAVE GOT TO. IT RUNS MUCH NICER NOW BUT SES LIGHT COMES ON AFTER LIKE 30 SECONDS.
    HELP
    Check out my car @ <a href=\"http://www.grodzmotorsports.com:8080/camaro2.html\" target=\"_blank\">www.grodzmotorsports.com:8080/camaro2.html</a> <br /><br />It\'s not what you make, it\'s what you spend! <br /><br />1994 Chevy Camaro 3.4, m5, t-tops, silver exterior, gray interior.<br /><br />Many modz! check out the site for details!
    Any garage with a GM Tech-1, Kal, or any other ODB-I compatible scanner can read it. You can even buy the equipment yourself, a decent multi-line live data display can go for anywhere from a few hundred to several thousand.
      i tried a regular obd-i code scanner. they do not work on 94-95 3.4 f-bodys.
      most of them are glorified paper clips essentially and you cannot use the paper clip method on these cars.
        Yeah, a simple code reader will not work. You need a scan tool. I borrowed one of these and it works on our cars.
        http://www.actron.com/product_detail.php?pid=16143
          excellent
            Retail is $400 but they are on eBay all the time for $250-$275 Buy-It-Now and even cheaper if you wait for one to be auctioned.
