So I've had my car (99 camaro) for three years and it runs great. That is until I drive at 70 plus on the freeway for more than an hour. As soon as I'm off the freeway and doing the stop/go thing the shifting from 1st to 2nd is hard. I mean it really jolts you. After I turn off the car for 30 min it stops. This is the only time it happens but for my job I have to make this drive once a week. Any thoughts?
Hard Shifting
Re: Hard Shifting
sounds like you need to get a valvebody upgrade. The sonnax kit is a good one. My brother's 99 just got it replaced after his 1-2 shift was doing the same thing as you when he went on long trips. Eventually he threw the p1870 code or whatever it is. This is a common problem with the 4l60e trans. Do some searches in the drivetrain section for a ton of info on the sonnax kit and the vavlebody upgrade
Oh yea and it costs around $300 to get the upgrade, you don't need your whole trans rebuilt which is niceLast edited by 97rs4life; 08-15-2006, 02:31 PM.
Re: Hard Shifting
I had a 99 and it had EXACTLY the same problem. I sold it about 2 years ago. Every day something on that car would act up and need repair, i sold it before i ever fixed the transmission problem. Every one told me it needed some kind of a larger valve.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Hard Shifting
used trannys go for as low as $752k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Hard Shifting
What's the fluid look like, My g/f just had a similar problem in her sebring, and her fluid was shot, once the tranny was warmed up, because the fluid was so broken down, it would shift hard and whine a little.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
