Hey. I've got a 96 Camaro and when I start my car it gets an odd noise while idling. It's like a high pitched whine. I was just wondering what it could be. Thanks for any help guys.
weird idle noise
Re: weird idle noise
could be your alternator, could be your fuel pump, could be interference in your speakers, could be your (anything else possible).
where is the sound coming from.
my guess is the alternator, i can here mine on my camaro and silverado.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
its not a problem, its normal wear and tear. GM fuel pumps are not suppose to have a loud whine noise during normal operation.
possibly the serpentine pulley assy ... mine was making a shreeking noise until the bearing went fully out, then it was a nasty hiss type sound ... hard to explain.\'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
you can buy a mechanics stethoscope cheap or just use a rubber hose to isolate the noise.
Originally posted by BLLDOGGyou can buy a mechanics stethoscope cheap or just use a rubber hose to isolate the noise.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
