Do the octane boosters work? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    9camaro9
    Very few engines need more than premium gasoline. You may want to fill with premium the tank before your night out as well as your night out-to give the computer a chance to adjust timing to the new octane level.
    IF you need more than 92 octane, most octane boosters are repackaged toluene/xlyene (which you can buy at paint stores by the gallon cheaper than at autozone by the ounce).
    http://www.gnttype.org/techarea/misc/octanebooster.html
    I like to mix 1 gal "octane booster" with 1 gal gasoline in a 5 gal can before dumping it in the tank and filling up (this helps mixing and keeps the undiluted chemicals away from hoses/paint etc.
    Every time I work out the costs, I cannot make low grade gasoline into 92 octane cheaper than buying the 92 octane to start out with (except for using low grade gas with a water/methanol "on demand" injection system)
    Manganese based octane boosters do seem to work and do cause orange-brown deposits with some minimal effect on the catalytic converter and O2 sensors. Seem to be best suited to a "once in a while" type of use.
    http://www.zzperformance.com/products1.php?id=215
    • #17
      Thanks for all the info guys
      <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
      • #18
        Originally posted by Timothy Luttrell:
        Try this link, some chemist figured this one out.... Considering this is also found in Aviation Gas. -Tim
        http://pesn.com/2005/03/17/6900069_Acetone/
        lol I posted that link several months ago (march/april), but the threads got closed for some reason; some moron (you know who you are) thought I was advertising for some chemical company. :rolleyes:
        but I've been using it ever since, with no problems. I also have xylene, but use that mainly for other chemistry applications (extractions, isolations, etc.), I just fuel up with 89.
        [ July 28, 2005, 10:55 PM: Message edited by: kinetic ]
