problem with 98 camaro... - FirebirdV6.com/CamaroV6.com Message Board
  • problem with 98 camaro...
    ok...when im gradually on the gas around 15-40 mph, my car kinda jerks back and forth....its not a tranny problem cause when i floor my car its fine...it almost seems as if its a fuel injector...i know for a fact its deff. fuel related cause when it jerks its like the fuels being cut off or leaned out...could the fuel injector be dirty? gone bad? or would it be a bad spark plug or something else??
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    If it works fine when you go WOT, it's probably not a spark plug. It could be your fuel system... I would run a bottle of Lucas fuel system cleaner and then replace the fuel filter.
      MAF sensor, trying cleaning or replacing it.
        2 days ago
      • Doodler
        97 Camaro base with expensive sounding noises
        by Doodler
        Still trying to find oil leak
