Last night I was driving my gf back two her house and the abs light came a not to fare from her house. i way house the abs light did not come on at all. I am going to check the ground cause I had problems with them before and that was the problem. I was just wanted to see If anyone may think it is something else.
ABS light on/off at random?
Re: ABS light on/off at random?
I had the same problem, the fix was a bad connection on the ground.
Under your hood, on the passenger side wheel well, right behind the battery is your Negative Ground post.
Clean the ground off, sand it down, make it bare metal whatever you have to do and re-tighten.
I have ABS INOP, brake and another light would just randomly flash and go away, come back later.. it was unpredictable. Now fixed.
Give it a shot!*Matt
