throttlebody bypass..will this work
This topic is closed.
How was I a smartass at all? If I wanted to be a smartass I could've been a whole lot more rude.
Lighten up. :rolleyes:Matt
1998 Mystic Teal Camaro M5
The 3.8's don't have any kind of coolant bypass, they get the coolant internally. If you unbolt the 3.8 TB and pull it out a little bit, you'll see what I'm talking about. I't located right at the bottom of the TB. There really isn't anything out on the market to block the flow of hot coolant to them, so you basically have to devise something to block it and withstand the hot temps too. Some TB Spacer's have the passage blocked, but they are hard to find.sigpic
Can someone find a TB spacer, because that would be well worth the money for the 3.8FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
Originally posted by Perry:
Can someone find a TB spacer, because that would be well worth the money for the 3.8Matt
Originally posted by 98Camaro3.8:
</font><blockquote>quote:</font><hr />Originally posted by Perry:
Is this the case?-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Originally posted by Fredless:
They say will not work on the F-body.
Is this the case?
I originally bought that spacer before they knew it was only for 99+. The gasket it came with is the exact one for 99+ 3.8s.Matt
remove TB.
fill coolant cavity (in TB) with tick gob of RTV silicon.
allow to cure.
replace TB.
voila! no coolant enters the TB.
this is graymans 'gob of goo' TB coolant bypass mod. enjoy.
Originally posted by grayman:
remove TB.
allow to cure.
replace TB.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...2 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...5 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
