throttlebody bypass..will this work - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • throttlebody bypass..will this work
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7987978499
    Sure, it'll work....on the LS1 it was designed for. ;)
    Matt
    1998 Mystic Teal Camaro M5
      I believe that it will work on the 3.4's too, but I'm not 100% sure. It definately won't work on the 3.8's though.
        what do i need for the 3.8 and thanks for the smart *** comment mister moderator i wasnt sure thats why i asked
          How was I a smartass at all? If I wanted to be a smartass I could've been a whole lot more rude.
          Lighten up. :rolleyes:
          Matt
            The 3.8's don't have any kind of coolant bypass, they get the coolant internally. If you unbolt the 3.8 TB and pull it out a little bit, you'll see what I'm talking about. I't located right at the bottom of the TB. There really isn't anything out on the market to block the flow of hot coolant to them, so you basically have to devise something to block it and withstand the hot temps too. Some TB Spacer's have the passage blocked, but they are hard to find.
              thats smart *** comments in my back since u were rude about it and everything could you atleast send me in the right direction to what i need
                Can someone find a TB spacer, because that would be well worth the money for the 3.8
                FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
                  ZZP has them for 99+. ;)
                  Matt
                    </font><blockquote>quote:</font><hr />Originally posted by Perry:
                    ZZP has them for 99+. ;) </font>[/QUOTE]They say will not work on the F-body.
                    Is this the case?
                    -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
                      Is this the case?
                      Says on their site that it's for 99+ F-Bodies.
                      I originally bought that spacer before they knew it was only for 99+. The gasket it came with is the exact one for 99+ 3.8s.
                      Matt
                        remove TB.
                        fill coolant cavity (in TB) with tick gob of RTV silicon.
                        allow to cure.
                        replace TB.
                        voila! no coolant enters the TB.
                        this is graymans 'gob of goo' TB coolant bypass mod. enjoy.
                        01 Firebird A4 3.42
                        Powerdyne @ 6 PSI
                        and other mods
                          Originally posted by grayman:
                          remove TB.
                          allow to cure.
                          replace TB.
                          thats a gamble. if it doesnt cure completely or something just goes wrong anyways, the silicon will break apart and get stuck in your coolant passages causing overheating. [img]graemlins/popcorn.gif[/img]
                          2000 3.8 A4 Pewter Camaro
