I have abnormally large amount of engine noise when accelerating. It starts around 2500-3000 rpm and stops when I hold a constant speed. I think it could be an exhaust manifold leak, but I'm not exactly sure. Any clue as to what this may be or if it is normal for this car.
Alot of engine noise...
Re: Alot of engine noise...
could be an exhaust manifold leak then or something like your egr tube leaking. Have you open the hood and tried listening for it at all? maybe have someone in the car rev it up for you to hear it in the higher rpms.
Had some friends of mine and a couple of piston engine aircraft mechanics that I work with listen to the noise in my engine. They seem to think it's an exhaust manifold leak. Is it to change the manifolds and gaskets myself, or should I take somewhere and pay to have it done? What is the normal charge for having a muffler shop do the repair?
Oh, one more thing, noticed a hint of a gas smell after pumping the throttle a couple of times. Any ideas as to what is causing that?Last edited by 98RED3.8; 08-28-2006, 01:28 AM.
sounds like a manifold leak, its not a hard fix and can be done in about an hour if you know what youre doing. if you take it somewhere id say about 50 bucks or so minimum.
Follow me!
Or this
i think muffler brothers on 40 can do it. if not check down on dixie at one of the 1932984093849 exhaust shops. i wouldnt take it to midas, they suck.
Follow me!
Or this
Got a bit of good news today. My exhaust manifold is not leaking. I have a leak somewhere on the exhaust pipe between the cat and where the pipe connects to the manifold. That will save me some cash.
thats good news then! where'd ya take it?
Follow me!
Or this
it would've been easy to find that out2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
