i've gotten mine wet including the coils..car has thrown codes for the module and for #6 misfire. i took everything off and dryed it out...when i went to hook up the module again i'm not sure which way the wire harness went...is there anyway to put it on backwards?? car seems to be runnin worse now. Also is there anyway to check the coils? i disconnected the battery to see if anything reset..which the light went off but the car is still misfiring. i also removed the #6 plugwire from the car and it runs exactly the same..so i'm thinking i've screwed up a coil..
Ignition control module
Last edited by Copperhead; 08-28-2006, 03:15 PM.98 bird Y87 SLP cai Msd Super Conducters Msd coils Splitfire Triple Platinums big bad Corvette servoTags: None
Re: Ignition control module
Well if you had a bad coil you would be missing on 2 cylinders. When my coil went bad it didnt even tell me which one or what cylinder was missing it just told me the code for "missfire detected". If you think its a coil just buy 1 coil from autozone for 25$ and test it in each spot untill it works. If that doesnt do it then it could be a number of things. Also autozone can test your ignition module for free.
when elcetrical stuff gets wet, you can't just dry it off.
You prolly shorted some stuff out, I'd get new coils, all 3 new, cause you car will run out of sync with only one new coil and I am guessing they all got wet anyways.
Originally posted by AceWell if you had a bad coil you would be missing on 2 cylinders.
Originally posted by UDLOSE98when elcetrical stuff gets wet, you can't just dry it off.
i'm pretty sure it's the front coil...i have MSD coils with only 2 or 3 thousand miles on em...so i'm ordering one from Summit in the morning. Also i took off the wiring harness and flipped it over and reinstalled it into the control module...runs alot better now.98 bird Y87 SLP cai Msd Super Conducters Msd coils Splitfire Triple Platinums big bad Corvette servo
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
