Im about to purchase a new fuel pump within the next few weeks and was doing some research on here and noticed that if I plan to put in a nitrous kit later(might start at 50 shot and go up to 100 shot),that Walbro pumps are good. Im not sure if I would need the regular 255 or the high pressure one. I dont plan to install nitrous for a while but figured since I need a pump now, I might as well already the aftermarket one. Also do I need to replace the regulator as well? If so, gm or aftermarket?
need a fuel pump
I have a walbro 255 in my camaro and it works great. Just took out the old pump, removed the bucket, and ziptied the walbro on and plugged it in. Works good NA and on the nitrous
nothing needed with the regulator
high pressure flows more so if you run nitrous or power adder, you have enough fuel there and won't run lean
