Intake Manifold Gasket? - FirebirdV6.com/CamaroV6.com Message Board
  • Intake Manifold Gasket?
    Hey all,
    I have a 94 3.4L camaro. I have coolant leaking from what i believe to be a cracked intake manifold gasket. If you look at where the water pump attatches to the engine, you can see a pin prick hole on the engine where air and coolant is coming out. Its definately not from the water pump and therefore i believe that its a cracked intake manifold gasket. I am very mechanically inclined and am willing to take on almost any job. I have replaced the clutch myself and all of the coolant hoses, water pump, and several other things in the car already. The problem is that in the Haynes manual it says something about removing the valve covers, heads and pistons??? Has anyone actually replaced these gaskets and are these the likely culprits for my leak? Also, how much harder is this job going to be than replacing say the clutch.
    P.S. Linkage would be nice, i read everything i could find on this forum and it was mentioned several times but no one ever talked in depth about replacing the intake manifold gaskets.
    Thanks in advance guys.
    Sean Smith
    Re: Intake Manifold Gasket?
    sounds like your lower intake manifold gasket, you will need to remove your throttle body, upper intake, fuel rail, lower intake, alternator, and coolant passages that also act as a bracket for the alternator. you will also need to remove your valve covers to make the job MUCH easier. Replace the lower intake gasket and the upper will need to be replaced as well.
      thanks for the quick reply. While i am in there, is there anything else i should look to replace, if im taking off the valve covers, should i just replace them. Also, if im going to remove all the cooling stuff, intake and everything, should i just continue removing everything and replace the timing chain because a buddy who is a mechanic told me i should? the car has 104000 miles on it.
      Again, thanks for the help.
      Sean
        once again, anything else i should look to replace while i am in there??
          new Throttle body and vavle cover gaskets
            heh, I have like 5 tb gaskets on mine lol
            my valve cover gaskets are RTVed onto the covers (i'm soo happy I did this)
              Good luck with the Job,but I don't really think it is the Intake Manifold Gasket,for the length of time is was an Auto Technician I have never come across an Intake Manifold crack and leak just like that.
              My engine is dismantled right now and I am trying to visualise the area you are speaking of,but I think you should Pressure Test the cooling system and see where the leak really is,cause you ain't sure and you will not feel too good to pull down all the Intake and stuff around it and reassemble and the problem still there.
                Thats what I'm saying dude! I had a HG leak. I was hoping it was just an intake leak. Redid the intakes and I bent my rod cause the HG was still leaking.
                There are tests you can run to find out where its leaking the best test is a
                cylinder leak down test which is only $39 at Harbor Freight!!!!!! cheap!!!!!
                Note: A compression test can tell you alot more than just how much your compression is, it can tell you where its leaking!!!!
                  At 104K I'd be inclined to replace the head gaskets as well since you've already got it torn down almost that far anyway....it's not much further to get the heads off. Maybe P&P the heads while they're off and consider doing a cam and valvetrain upgrade. The possibilities are endless!
                    no crap, the head gaskets are only $30 and the bolts are $30 so = $60
                      alright, so from the looks of it i will be replacing the following.
                      Head gasket and head gasket bolts.
                      Lower Intake manifold gasket
                      valve cover gasket,
                      upper intake manifold gasket,
                      throttle body gasket.
                      um. what is PandP port and polish??? sorry man, im a way newb at this. Also, could i get some links to a new cam and valvetrain upgrade, something good for this car but not too too expensive. Thanks for all the help guys.
                      Sean
                        you will need new rocker bolts as well.
                        port and polish, yes,
                        and for the valve train
                        www.zzperformance.com
                        www.ftpp.net
                        www.abbottracingheads.com
                        www.compcams.com
                        www.summitracing.com
                        www.3800performance.com
                        www.wbodystore.com
                        what do you think? good enough start?
                          I've got re-useable Harland Sharp or Comp Cams rocker arm bolts. Never been used.
                            i too have comp bolts...., I am just gonna end up selling them to recycling, no one wants a lot fo my parts.
                              sell them to the recycling center? ARE YOU MAD?
                              What other parts do you have that youre gonna sell to the Recycler???
                              Got any UIM bolts?
                                6 days ago
