Stuttering - FirebirdV6.com/CamaroV6.com Message Board
Stuttering
  • Stuttering
    Hey guys. My 97 3.8 Camaro will randomly studder. I'll be driving down the road, and it'll stutter. It's not at a certain RPM, a certain speed, or anything, it's completely random. It almost seems like the car quickly dies, then comes back, all within a second or two. At first, i thought nothign of it, and thought it was a fuel problem; thought I needed to clean my injectors. I put some injector cleaner in my tank, and it's still doing it. It did it really bad last night, I was about to pull over. I got up to abour 35mph from a complete stop, with it doing it the WHOLE time, then it just stopped. Any idea what my problem is?
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Stuttering
    mine was doing something similar to that a while back. change your plug wires. i had just put on a new set and it started to act up, come to find out they were defective wires. swapped some new ones on and it was good to go. it could be one of your wires burned through or gets hot and arcs to something. does it do it after the car warms up or all the time?
      Re: Stuttering
      maybe the fuel pump?
      K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
        Re: Stuttering
        have the icm and coil packs checked. check your fuel pressure to see if maybe the fuel pump is starting to go or maybe the fuel pressure regulator. check the plugs and wires, make sure the wires are not sitting on one of the exhaust manifolds also. only other things that come to mind are maybe a vaccume leak, or erg valve getting clogged.
        Follow me!
        Or this
          Re: Stuttering
          OK. It usually only does it when it's warmed up, but I wouldn't be surprised if it did it when it was cold. I'll check, thanks for the info guys.
          ~97 3.8L V6 Camaro~
          A few things
            Re: Stuttering
            definatley check ur plugs and wires.
              Re: Stuttering
              are you sure it isnt your torque converter not locking properly?
                Re: Stuttering
                probably a fuel issue (so AFR issue)
                My car stutters, but its because I dont have my AFR tuned right yet
