Smelly clutch - FirebirdV6.com/CamaroV6.com Message Board
Smelly clutch
  • Smelly clutch
    Okay, fairly simple question here. My car has 37k miles on it, but I have no idea how much the previous driver beat on it. The clutch seems strong as far as I can tell, and I've had no real problems with it since I bought the car. However, after I get home from work I can faintly smell something nasty, instantly I blame the clutch, but I've heard that brakes and a bad cat can also be to blame. Then again there is a slightly steep hill (that I always have to start from a stop at the top) just before my house. Would switching from stock to the loudmouth burn out my cat? Anyone have suggestions as to what is causing this? Or am I just crappy at shifting? Didn't think so until now..
    01 V6 Firebird, Flowmaster catback, Navmate gps, B&M Ripper.
    If your clutch isn't slipping, then leave it alone unless you're planning on racing it alot with a modded engine. I still have my stock clutch, and my car is a 96.
    It may be a bad/clogged converter. They are basically cheap on ebay. I went with the Magnaflow #94009, and it worked great! Something like this.
    Also, did you ever get (or have) an SES light?
      Never had an SES, I'm guessing is either a bad cat (Which I plan to replace in the near future anyways) or just this annoying hill every day too and from work.
        Did someone teach you that putting aftermarket parts on your car will wear out other parts faster??? lol, they were right. But the cat-back is after the cat, hence the name, so it wouldn't burn out the cat. But it could be a bad cat regardless of exhaust.
        FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
          and if it is the cat, you can have it replaced for free because its under warranty. 8 year 80,000 miles or something like that. i just had mine replaced because it started rattling. any chevy dealership will warranty it out.
          <a href=\"http://www.cardomain.com/id/cops_suck\" target=\"_blank\"> 2000 3.8L Camaro M5 </a>
