Throttle pegged this morning, VERY HIGH IDLE :P - FirebirdV6.com/CamaroV6.com Message Board
  • Throttle pegged this morning, VERY HIGH IDLE :P
    Little background:
    1998 Camaro 3.8 m5
    Having a small misfire issue on cyl. 5 (unrelated i think)
    every now and then the car runs like a champ and every now and then it misses badly but is still drivable as long as i dont gas it to much and take my time accelerating.
    This morning was one of the in the middle days where the car has a minimal ammount of hesitation and is running decently. I pull out of a stop light (getting ready to get on the highway) and I push the clutch in to shift into second and BAM RPM are redlined and the car is racing. I shut off and rolled to the shoulder. I started it on the shoulder and wooosh the car is racing(were talking 6k RPM instantly). So i quickly shut it off. Only thing i can think to do on the side of the road is get out and play with the throttle to see if its physically stuck. It wasnt. I opened and closed it a few times quickly by hand (Just pulled on it) got back in and was able to make it to work. I imagine ill have more info after i drive'r home for lunch, but anyone seen this before? Any thoughts?
    Thanks
    --Pigpen1204
    (Everett)
    Re: Throttle pegged this morning, VERY HIGH IDLE :P
    Vacuum leak? But that would have to be one serious leak!!
    Maybe your cruise control servo pulled full throttle on you? Having any problems with cruise control lately?
      I rarely use the cruise control, so its hard to say. I was having a problem with the vacuum line the connect near the TB (the one that has an L shape plug). It kept blowing off of there for whatever reason, but i put a zip tie on that and it hasnt happened since, and as far as I know thats the only vacuum problem i have/have had.
      On the drive home at lunch i had no issues with it pegging the throttle again. Only time will tell i spose.
      Thanks for the help
      --Pig
        Yeah...keep an eye on it. Hopefully it won't happen again.
          I would say cruise control also, mine stuck and it took me awhile to figure it out but diconnecting the cruise control from thr TB is worth a shot.
            I think that's a good suggestion. (since you don't use the cruise much anyways)
              OK figured out what was causing the high revs. The floor mat. It was slightly rolled up and when i pushed the gas it pushed past the roll it got caught.
              So if this happens to anyone, check your mat.
              Thx for the help anyways guys
              --Pig
                Yeah, I've done that!!
                Sometimes we get wrapped up in the technical and don't see the obvious.
                Glad to hear all is cool.
