power steering ? - FirebirdV6.com/CamaroV6.com Message Board
power steering ?
  • power steering ?
    What hose is the one be hind the right side of the pulley? That hose is leaking for me and I have to change it. Is it had to get thoughs lines off the power steering?
    Re: power steering ?
    not hard
    pull off the drive belt
    then get a 13mm deeep socket on the 2 powersteering bolts that hold the pump on. (you can get to them through the holes in the pulley)
    pull it off
    use pliers to pull off the hose
      its not hard but if you give a picture or at least some info of your car that might help. but, since you didn't, I'm going to assume to own a 03 dodge neon and tell you thats the return line. :notreally:
      2000 3.8 A4 Pewter Camaro
        5 days ago
