need help MAF sensor code is being thrown - FirebirdV6.com/CamaroV6.com Message Board
  • need help MAF sensor code is being thrown
    I have been having problems with my 97 firebird V6 3.8L, every time i drive my car for like 4 miles it starts bucking like its losing fuel or like a MAF sensor is bad every time i stop it stalls. i have replaced the Mass air flow sensor like 3 times, its seems to fix it for about a week and then its starts doing the same thing all over again, i have even replaced the connector that plugs into the mass air flow sensor also a foot of the wiring to it. still not fix running low on cash from this thing any ideas of what it could be. oh and it seems like the battery gauge, seems to slowly go down as i drive but stays above 13 around 14v or so. PLEASE CAN ANYONE BE OF SOME HELP?????????????????????????????????????????????? ???????
    Re: need help MAF sensor code is being thrown
    what code?
    on a sensor so sensitive as the maf, doing the wiring yourself is very bad (unless you know what your doing)
    Ever tried running your engine and unplugging the battery?
      No i matched the wires perfect i know that i made sure i had good contact, I have never done that with the battery what side do i disconnect?? neg. or pos. and what will happen?? The code i throw "P0102 Mass Air Flow (MAF) sensor circuit low frequency" thanks for the input so far, hope you can give me more on this problem
