Tps location on 01 fbody? - FirebirdV6.com/CamaroV6.com Message Board
  • Tps location on 01 fbody?
    this is a stupid question.. but where is the TPS located on an 01 camaro does anyone have a pic?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: Tps
    Its apart of the TAC assembly which is #3 and I don't think is serviceable
    2000 3.8 A4 Pewter Camaro
      Re: Tps
      uhh not servicable huh that ****ing blows so what happens when it goes bad?
      btw can you post a list of the numbers and what they are please?
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        Re: Tps
        (1) Fuel Pressure Regulator
        (2) Ignition Coils/Module
        (3) Throttle Body
        (4) Engine Coolant Temperature (ECT) Sensor
        (5) Camshaft Position (CMP) Sensor
        (6) Crank Position (CKP) Sensor
        (7) Engine Oil Pressure Sensor
        (8) Heated Oxygen Sensor (HO2S)
        (9) Fuel Injectors
          Re: Tps location on 01 fbody?
          yeah ive read another post where the tps went bad.. had to replace the throttle body...
          check a junk yard for it, probably much cheaper.
          chet's just went bad.. he replaced his TB, fixed all.
          *Matt
            that is so ****ing stupid that you have t replace the whole thing.. it is so hard to find a newer f body in a junk yard around here..
            2001 Camaro 3.8 A4
            1991 3000GT VR4
              I have one sitting on the shelf in the garage, which is off a 01. I bought it at a junk yark for $100 when mine on my 99 was sticking. Interested???? whats your email address and i can send you pics of it, all it needs is a good cleaning, i guess it works fine, i sold my 99 before i installed it.
                Is this not a replacement TPS? http://www.autozone.com/servlet/UiBr...tion+Sensor%29
                This is for a 99 Camaro, 3.8 liter, but it should be the same. What would you do, drill the rivets out, and tap the holes in the TB for bolts to hold the new one? I also believed that the whole TB would have to be replaced, so I am confused about this one.
                Also, is this the TPS or the TAC? Anyone?
                  tps is on other side?
                    chet has a 98 with the angled throttle body
                      doesnt matter i think its like that on all.
                      *Matt
                        this kind amakes me mad cause i called autozone and they said they didn't have **** i ended up buying a new TB but i will test this out with my old tb and let ya'll know if it works...
                        2001 Camaro 3.8 A4
                        1991 3000GT VR4
                          "not available in store or on the web"
                          my autozone says they "have everything" but I know thats a lie
                            Where did you end up buying the new TB from?
                              i just called autozone with that part number and they were dumbfounded they had no clue what was going on..
                              a guy on the forums
                              2001 Camaro 3.8 A4
                              1991 3000GT VR4
