So my mom's 1996 buick lesabre won't start at all. The battery has a lot of life, the fuel pump is on, the key is clean, and I don't know why it won't start. The security light keeps on flashing while the car has the ignition switch turned to on. Both keys that came with the car aren't working. Have any of you had any problems like this with your f-bodies or know what is wrong with the car? Thanks.
security key problem?
Could be the wires going to the key cylinder. Is that PASS-Key II? F-Bodies have a common problem where the wires that read the chip in the key get torn loose and you'll have problems like that.
Be aware that after a certain number of tries, you'll have to wait like 5 minutes to try again.
The Security light tells you it's something involving the key or the chip.Matt
1998 Mystic Teal Camaro M5
I've heard sometimes dust gets in the ignition, try blowing compressed air into the ignition
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
