Recommended Mods on 3rd Gen? - FirebirdV6.com/CamaroV6.com Message Board
  • Recommended Mods on 3rd Gen?
    Greetings all,
    I recently aquired a 1984 Pontiac Firebird, 2.8L V6. It is carberated not EFI sadly. However to get to the point, what are some recommended modification/upgrades/replacements that can/should be done with a car that has not been very well taken care of?
    I have passed california smog, so it is running okay, but it does not seem to have the get up and go I would have thought it should. Granted I am use to driving a 1987 Toyota Supra Turbo.
    Any advise offered would be great, thanks!
    Jurrel<br />1984 Firebird<br />2.8L V6<br />No mods
    You may want to check in with the 3rd Gen. Forum, I think they've got a couple of mods you can do for an '84 like headers & stuff.
    <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
      get a 4th gen!!!
      ;) [img]smile.gif[/img] [img]graemlins/dunce.gif[/img]
      It just depends on how much you want to spend.
      As always start with the basics - induction and exhaust. Maybe replace or rebuild the carb. Then there are always heads/headers/cam but it may be hard to find for that setup not sure. Maybe look into dropping a new engine in it - you'd have to do your homework on that though.
      01 Firebird <br />Whisper Lid - K&N<br />Raised Air Lid - Free Ram Air<br />Borla Cat-Back Quad tips<br />3.42s with lsd on the way
        Well have been looking at the 3rd gen area, not alot there for info of late.
        As to the engine, I am debating updating it eventaully to either a 3.4 V6 or a 305 V8 with EFI.
        At this point, I was wondering how good chassis stiffening is. I know there are ALOT of subframe connecters, panhard rods, strut tower rods...etc out there, I am using it as a daily driver, not for race track use..
          A great place to get advice is at http://www.thirdgen.org . There are quite a few folks on the V6 forum there, and they will surely help you out.
          16 years old with no car and big dreams...
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
