when i turn left my turn signal lever will stay on and i will have to push it back up to turn it off. i'm guessing i need a new switch but i dont know
turn signal switch
Re: turn signal switch
your bulb is burn out. mine just went out a few weeks ago and was doing the same thing.\"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
if when you turn the signal, is stays solid, you need a new bulb. If it nevers clicks back when you turn straight or the other direction, you need a new switch.
