whats the proper way to adjust my high and low beams. I know you should be on a level surface and facing a wall, but how far should i be from the wall, and how high should the low beam be, how high should be high beam be? thanks
Headlight adjustments.
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
Re: Headlight adjustments.
What I normally do is park about 40 ft from a wall and adjust my lowbeams right at the bottom corner where the ground meets the wall, then try to adjust them where the beams are about 2 ft apart from each-other. I usually have to get in and out of the car quite a few times to physically see the results and I get it where I like it.
I adjust the high beams the same distance from the wall, but I go about 2 ft higher than the low beams.
A shopping mart is normally good for a large wall, plenty of room and this adjustment...late at night when they are closed.sigpic
GM says 25ft. I would just get out on a road far from anyone so no one drives up and adjust that way
THANKS, thats all i needed to know.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
