Oil Pressure and Trans Temp - FirebirdV6.com/CamaroV6.com Message Board
  • Oil Pressure and Trans Temp
    I am trying to get my Oil Pressure and Trans Temp hooked up. I am curious if anyone has written instruction or could tell me where I need to screw the adapters into.
    I think I found the Oil Pressure sensor, but it doesn't look like a standard socket and it's super long. Is there some special Oil Pressure Sensor Socket I need to purchase?
    Thanks for the help.
    You should post this in General Tech, that would be a more appropriate forum.
      these for gauges? If so, my autometer trans temp gauge, I just screwed the sensor right into the side of my tranny. There is a little hole that works perfect for it with no additional parts needed. Look on the drivers side, about halfway up above the cable.
      http://www.bowtiev6.com/
        This is general tech, LMAO [img]graemlins/banana.gif[/img] [img]graemlins/twak.gif[/img]
        FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
          maybe it was moved already perry
            You mean the tranny on the f-body has a place to screw in an aftermarket sender? The automatic? GM couldn't be that nice......
            Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
            • 187shark
              by 187shark
