Beginning to Mod this Year!! - FirebirdV6.com/CamaroV6.com Message Board
  • Beginning to Mod this Year!!
    ok so heres my story. i'm a senior in high school and i am 17 years old. my school has this awesome program where i pick any topic i want adn i research it all year for a grade. and i have to be an intern at a place. so of course i chose cars and engineering and automotive performance. i am an intern at a good friend of mines performance shop. and over teh couse of the year i want to mod my car so they can teach me how to do modifications and what not. i was wondering what are some basic mods i should do to start. and by the end of the year i need to do something big as a project like a cam install, heads, etc etc. lemme know what you think i should do. so far i have a whisper lid and flowmaster cat back. i was thinking of doing the following things:
    -160 degree thermostat
    -cold air induction
    -manual fan switch
    -mabye gears and torque converter
    i'm just looking to make my car quicker and more fun to drive. please gimme your suggestions on what to do over the course of the year and what to do for a final project!!! thank you. and i have a 2002 Camaro A4 by the way.
    02 Camaro:<br />Whisper Lid, Cat-Back Exhaust, K&N Air Filter, Glow Gauges
    Re: Beginning to Mod this Year!!
    What good does the manual fan switch do?
      It turns the fans on earlier than the stock thermo sensor. The stock sensor kicks in when the engine temp is over 200 degrees. If you install a manual fan switch, you control the engine temp. Just don't forget about it or you'll be sorry! Especially if someone else ever uses your car and doesn't know about it.
        if you are gonna get gears better get a LSD/posi too!
        if you do get gears, the torque convertor will help it out
        if you get a torque convertor then a cam would help it out
        if you get a cam, then heads would help it out
        good luck
        if you get gears youre gonna have to get the computer tuned for them.
        get a mail-order tune
          here's what i would do, start with cool air induction. then upgrade the spark plug wires, usually any platinum plug works fine and you more than likely have them as they are so common, then i would get a high flow cat, then go for the gears lsd posi and torque convertor, then a tune chip, then if you still have time and/or money get a cam and/or heads. you should be happy by then :naughty:
            cool cool thanks for the feedback. what i would love to get are headers but from what i hear they are a pain in the *** to install and are not really worth the money it takes. i think i will be fine on money for the gears, lsd posi, torque converter, and cold air inake. i jsut dont know about the cam. i would love to get one due to the obvious performance gains and who doesnt love the lopey sound :) but how much does a cam cost on average and install and all that, i will be doing the install with the help of the people there so cut the cost in half or so. thanks again though
              posi = lsd (same thing) I know what you meant though, just wanna clear it up
              I would do gears & LSD at the same time, of course
              I've heard bad things about platinum tipped plugs
              I would not get a tune chip unless that is your only choice
              Cam install for me would run real cheap, maybe $400 would be plenty for everything
                id stay away from platinum plugs.
                Follow me!
                Or this
                  NGK-TR55s or whatever (depending on your mods/needs), plugs (and the whole electrical ignition) has been talked about many times
                    so instead of platinum plugs what should i get? is it called irideum (sp)?also to go along with the cam what should i do? i know pushrods are a must right? mabye rollers? and is the ZZP water pump pullie worth it? thanks again :)
                      dont bother with the zzp water pump pulley, our cars are underdriven already and you won't see much if anything from it.
                      http://www.bowtiev6.com/
                        go ahead and do pushrods and rollers if your going to get into it to swap a cam but yes our cars are a lil underdriven stock, i was going to get a underdrive pulley then told it would be a waste
                          i need help on choosing a cam for my 99 camaro 3.8 automatic i want hp and torque and this seems like a good way to go if anyone can send some links on which one to get i would appriciate it
                          send to mulloynet@netzero.net
                          http://www.cardomain.com/ride/2442428
                            this is like the cam bible, http://forum.camarov6.com/showthread.php?t=46236 , i have been reading it for a little and it really is useful. your car looks really nice, where in maryland is deale? i live in columbia.
                              anne arundel county south of annapolis
