Hey all. Before I took a trip to SC, I changed my wires, plugs, and all three coils and fuel filter and I was suprised to notice that I used almost 9.5 gallons after 300 miles. WOW. I quess I needed a tune up.
32 MPG after tune-up
Ya I get about the same MPG 30-33. Do your PCV valve also, so you could say you did a complete tuneup.1999 Pontiac Trans Am M6 Far from stock.....
how in the world do you guys get this gas mileage. My car is stock and I'm lucky if I get 24 MPG. I don't drive hard either.1996 Polo Green Metallic Camaro:<br />SLP CAI, Carsound/Magnaflow 3\" in/out cat, Flowmaster 2.5\" cat-back... sounds great
Originally posted by BobsSilverSix:
Dude it's a 97 3.8, it's in his profile....
05' CTS-V
00' Camaro - SOLD :(
My car is stock and I only get 14 mpg...SOLD - 1999 Black Firebird<br />A4, T-tops, 3.42 gears, Y87 Package<br />[Appearance mods] Chrome side vents, Pontiac metallic silver rear inlay<br />[Performance mods] TSP Rumbler<br /> <a href=\"http://www.cardomain.com/id/eminemz115\" target=\"_blank\">PICS</a>
You guys with A4s, make sure you aren't getting the infamous torque converter clutch isolator valve wear... causing your TCC to not lock up. If you've got 3.42 gears, standard tire height (IE stock tires/rims or taller rims with lower profile tires) and an A4, your car should be just around 2000-2100 RPMs on a flat surface cruising at 65 MPH. If you're at around 2500 RPMs, your TCC isn't locked and you're wasting fuel (as well as overheating your tranny). This is common on the 4L60E and it's a (relatively) easy and cheap fix for a tranny shop (I paid $316). After getting the fix done, my TCC is locking up again and my highway gas mileage is getting a LOT better (went from an average of 22 MPG to 28+). For reference, my car has about 64,600 miles on it. There's no set time for when this happens - I've read about guys who had it at 40K and guys who didn't get it until 90K. Usually you'll notice this on very long trips where you'll get a SES with a P1870 code and a harsh 1-2, though I wasn't always getting those.
Things like plugs, wires, O2 sensors, etc all affect gas mileage, so does a new air filter (if your paper one is old, I use a K&N), PCV, etc. Cars with 3.42s will get slightly worse mileage than ones with 3.08s, but it won't be a huge difference. Severe drops in gas mileage can usually be attributed to these previous things.
[ May 22, 2004, 04:13 PM: Message edited by: Dan Vincent ]<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
I think my intake and exhaust actually help my hwy mpg cause of the increased air volume. My city is horrible though like 12 or less but I drive in Atlanta.Mods: SLP CAI, SLP loudmouth, Removed MAF screen, Remote Fog lights, Taillight Blackouts, \"Firebird\" in third brake light all on Kumho 245/50 R16\'s
27 average most i eve go was 36MPG high way....thos days are overwww.turbov6camaro.com
1997 3800 Series II Camaro
I got 36 mpg running between 75-85 mph the other day when I went to the Kidrock concert in Wichita, don't know how but hey I was happy. The best I ever got was 42 mpg following my dad with our car trailer but that is the reason because I was riding his draft.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
-235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
What happens is you bring your car to the tranny shop, they hook it up with the scan tool, and drive for a bit. Watch the torque converter slip and TCC apply duty cycle. If the TCC apply duty cycle is very high and the slip is very high, the TCC isn't applying. Note that the car has to be warm enough for this to happen (it took my car about a half hour to 45 mins worth of driving for it to stop applying).
What happens is the TCC regulator/isolator valve in your valve body is not a straight on-off mechanism. It's pulse-width modulated for a soft apply (so that you don't feel the TCC engage). This PWM of the hard aluminum valve wears the soft aluminum valve body, causing the tranny oil to leak past the valve, causing no apply or slippage. The PCM sees this and thinks the converter itself is dying, shifts the line pressure to max and flips the P1870.
It's a relatively simple fix. The shop removes the valve body, reams it out with a sonnax reamer, and installs a Sonnax TCC regulator/isolator valve fix kit. The kit is about $40-$50 and the reamer is about $100 (most tranny shops should be doing these repairs and should have reamers already).
Here's a link to the Sonnax valve kit:
http://www.transmissionspecialty.com...54-03K-04K.htm
Mike at Aamco in Westfield, MA quoted me about $350 and charged me $316. Sadly, you're in AL, but ask your buddies for a reputable tranny shop. This is bread n butter work for most tranny shops, so it should be relatively quick for them. They'll give you a new filter and fluid too, gasket, etc.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
