hey guys is it possible to clean the intake manifold while on the car there is so much black caked in there its not even funny i would take it off but i heard its a major PITA
intake manifold
Re: intake manifold
sure, but there are parts that are really hard to reach. It isnt that bad removing it, you will need a new upper intake mani. gasket, very cheap. Honestly it would take you no more then 30-45 min for a first timer to pull the UIM.
This way you could sand and pait it as well.
Re: intake manifold
not particularly, there are a total of I THINK....8 bolts or so, you need to remove the break boost hose from the back but wait till the manifold is loose and you can slid it forward before undoing it. there is another connection on the pass side of the IM which requires Torx bits to remove, 2 bolts there. Then finally unbolt the coolant hose and the EGR.
