Synthetic worth mywhile? - FirebirdV6.com/CamaroV6.com Message Board
  • Synthetic worth mywhile?
    im getting ready to do my second oil change since ive had my car and im debating on switching to synethetic. its a 98 with 70k on the clock mods are cutout and intake. im thinking of going with mobil 1 and a k&n oil filter. thanks
    Re: Synthetic worth mywhile?
    There is a split between the members on this forum about coverting to synthetic oil on a high milage engine. Some have experienced leakage from seals when they put in the synthetic and have blamed the detergent addititives in the oil for washing away sludge and varnishies that kept their old seals sealed.
    I cannot dispute that those people experienced oil leaks, but I cannot reason the detergent as the cause.
    I switched to synthetic oil (Mobile 1) when I first got my FB at 80,000 miles. I'm now at 107,000 miles and no leaks have developed yet.
    The descision is yours.
      well right now i have no leaks and everything is in good running condition im just afraid because i put synthetic in my honda that i had and it got a small leak around the plug that i didnt know about till t was too late. im just afraid to have the same happen to my camaro. i change the oil in the camaro about every 2500miles and about every 2k in my trans am. so i keep a better eye on things but i dont want leaks and have to deal with them because i have to stick with synthetic.
        well i wanted to try to go that way about 2 years ago and ever since then i haven had oil leaks. i don't know if it had anything to do with that. but it seemed like if there was a way for anything to get out. the thin synthetic found it.
        i changed back and will NEVER do it again.
        just my .02
        WAWA-A-HOLIC
          in my camaro i bin useing royal purple ever sin i had it 60k and now 115k later still no leaks i say go for it get the synthetic brand
          2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
            if i tryed the synthetic blend then slowly moved to fully synthetic would that be any better? almost all dyno oil is basicly the same and if i stay that way ill prob just run penz 10w30 i run penz 20w50 in the t/a and i love it ive always ran penz in that car with old motor and the new one but i am trying to do waht i can to keep my daily driver (camaro) in good shape and mabey gain some power in the process!!
              My 2000 camaro has had nothing but mobel 1 synthetic and Im at about 64,350 and I have never had a leak.
                gotchocmilk39 when did you switch or has it been like that since new? im just wondering since ill be switching from dino to synthetic and i know horror stories so thats one reason why im kinda worried. like i said ive had one incident before though even though it was just a leaky plug and the car only held 3 1/2 qts anyway
                  i use full synthetic pennzoil platinum only got 68k miles no leaking or anything but id say if by some chance it does "cause" a leak from washing away dirt and sludge then let it just check where u park if it leaks it will leave a fresh spot before it gets "to late" u should notice the leak. id rather know i hve a leak or something then try and cover it up
                    well I dont know what it had in it when my mom bought it New but after that it only had synthetic.
                      hum..... what would some of you that have gone synthetic suggest? ive always gone with mobil and thats what my uncle runs in his t/a and he has never said anything bad about it
                        well i like pennzoil, even though they use valvoline in stock car racing or atleast they advertise that they do i dont think i like it to much. never used mobile im sure the majority of the top name brands are just as good as the next anyway so i wouldnt sweat it to much. id just advise that when u finaly decide what u want to use to always use that kind instead of changing it up every time u change ur oil. :tup:
                          I use Moble 1 because it is more readily available than others around here. As for which one is better than the other, I would bet that any one brand is not better by much over any other brand.
                            i agree that most the dino oils are basicly alike but unsure of the synthetics but i would almost assume it would be too. what about the blends should i do a blend then go full synthetic?
                              i dont think that would be necessary, but changing oil types 3 different times in a row could be bad enough? people always told me if ur going to use a type of oil stick with it because changing it up is hard on ur engine or some bs... id go straight to full synthetic. i bought my car and im sure they used regular oil and my first oil change i put full synthetic in it and been using it sense with no problems.
