Can I use a bigger oil filter? - FirebirdV6.com/CamaroV6.com Message Board
  • Can I use a bigger oil filter?
    Oil change time is comming up for me. I use Mobil 1 5W-30. My car will have 100K at the change. I currently use the K&N Gold Series filter, PN 1001 (or 101...whichever is recommended for 3.4s)
    My question is can I use a bigger oil filter? That one seems so damn small! With synthetic, I try to go 5,000 miles at each interval. I know the oil will be fine for 5K, but the filter seems too small to really hold all the crap that it filters.
    Can I use a bigger filter to increase the capacity of crap it holds? If so, what PN will it be? Preferably K&N, since I like the anti-drainback valve feature.
    Oh yeah, with a bigger filter, would I be able to use 5 qts of oil, instead of 4.5 qts?
    Thanks for all the help! [img]smile.gif[/img]
    --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
    i dont know about the 3.4 but i know the 3.8 can handle a bigger filter, i have the PH52 or something like that Fram, its a longer filter
    <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
      3.4L and 3.8L use the same size oil filter. stock is AC Delco PF47. the bigger filter is PF52.
        Oh sweetness!!
        I did a search after I posted (yeah, shoulda been the other way around [img]smile.gif[/img] )
        Can I use all 5 quarts for the 3.4? I know the 3.8s can use 5 qts.
        And does anyone have any other PNs for some other oil filter brands?
        Thanks, dudes [img]smile.gif[/img]
          Any 3.8's notice a high level on the dip stick after using a PF52 and 5 qts of oil?
          I just changed mine last weekend and it seems higher than a standard 4.5 qt oil change. It lies about 1/4 inch above full mark.
          (However this may be the way my car is sitting in the driveway)
          --Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
            On flat level ground with 5qts oil and a PF52 my 3.8 is on the nose perfecto.
            2002 5-spd NBM Camaro
            Details: www.1lev6.com
              Oil level? WTF is that? I have this spiral dipstick ...
              -Rob
                <blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
                -Rob
                <hr></blockquote>
                [img]graemlins/rofl.gif[/img]
                I know, you can't read off it for shiz
                ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                  Spiral Dipstick, sounds like a camaro. =) A firebird wouldnt have one of thoughs.
                  97 Special Edition Bird , Short bus stlye special
                    I use the AC Delco PF-52 (has the anti-drainback feature and costs less than K&N) and use 4.75 quarts per oil change. This puts the oil level near 3/4 of the full range. A full 5 quarts would probably be at the top or slightly higher.
                    \'01 Camaro M5 1SA \"Lightweight\" hardtop, Bright Red, Ebony cloth, FRA, Whisper Lid, B&B cat-back, Torsen 3.73 LSD, HPPIII (93 octane setting)<p>\'00 Camaro SS M6 T-Top, all GM and most SLP opts., Bright Red, Ebony leather, 4.10s, SLP long tubes, Loudmouth, CNC Stage II H/C, etc.
                      <blockquote>quote:</font><hr>Originally posted by CamaroBill:
                      A full 5 quarts would probably be at the top or slightly higher.<hr></blockquote>Is there a problem with having too much oil?
                        just a 1/4" over, no...but way too much is bad...
                          OK, I did some searching...
                          The PF52 is used by the 4.3 V6 in S-10s and Blazers. So I plugged that info into the K&N site, and the PN for K&N Gold Filters is HP-2001.
                          Found a pic of the AC Delco PF52...it certainly is bigger! :eek:
                          I'll see how much more the K&N is in my area; if it's a lot more, I'll get the AC Delco.
                          EDIT: pic link didn't work so I took it down.
                          [ March 03, 2003: Message edited by: TheV6Bird ]</p>
                            It's also used by the 96 corvette's and 95-96 SS impala (same engine) I just bought the puralator pureone filter for my car but forgot what # it was.
                            96 Camaro RS A4 T-tops<br />Loudmouth <br />and other audio mods
                              I like my fram x2 it lasts for 7,000 miles... to bad the car leaks all the oil first
                              <b>Black 1996 Firebird</b><br /><b>Newest Edition: Harlan Window Switch</b><br />Nitrous Express Kit,ASCD big block hood, SLP Loudmouth, CATCO hi-flow cat, CAI, -Maf, LSD, Flameball Shifter<br /><b>Best N/A 1/4 in</b> 15.216 @ 89.82 <b>Best N2O 1/4 in</b> 14.352 @ 97.46 &lt;--w/clutch slippage<br /><a href=\"http://www.geocities.com/motorhead69/\" target=\"_blank\">My homepage</a><br /><b>AIM:</b>MotorHead75068 <b>YIM:</b>MotorHead69
